Works brain dyno with a/f coming soon
Works brain dyno with a/f Here! page 4
Go to page four of this thread for the goods!
I’m tired of wondering about this, so I made an appointment with Altered Atmosphere (www.alteredatmosphere.com/) in Maryland for next Friday the 15th.
I will post the results that day for all to see. I can’t believe this hasn’t been posted yet, so I will settle the controversy. This will be the 93 octane map that everyone wants to see.
I will dyno a stock evo with 1000 miles on it and I will dyno an evo with 6000 miles and the 93 octane brain flash. Then I will remove the muffler and add a delete pipe and make some more runs on the WORKS equipped car.
The runs will be on a AWD dynojet with a wideband.
They will not be able to map the boost curve unfortunately? I don’t know what is required to do that but I guess they can’t. And I don’t have a boost gauge, but maybe I can borrow one for a day.
BTW, I love the works brain flash! It makes the car so much more fun to drive. I just can’t recommend it to anybody with all this drama going on. I can tell you that when my buddy drove my car, I could see carbon coming out the tailpipe when he got on it. Don’t know what rpm’s that was. I have yet to hear it ping, even when driving on the track in 110 degree weather. Sometimes, it does feel like it may be pulling the timing at about 5k, but it seems like the EVO is so inconsistent from run to run it is hard to tell. I just can’t wait for WORKS to get their boost control function perfected.
Re: Works brain dyno with a/f coming soon
This way its apples to apples and you'll have two results, which would provide more accuracy.
Re: Re: Works brain dyno with a/f coming soon
Originally posted by 954DRGSR
To make this a worthwhile comparison you would need to compare the works ecu vs what each individual car is stock. Why not run both cars with the stock ecu (from the 1,000 mile car) and then run both cars with the works ecu (from your car). Recall that different evos put out diff hp numbers stock.
What about relearning time? Should the car be driven around the block first before dyno'ing with a new ECU?
Originally posted by SuperchargedGTZ
what controversy are you referring to? I was going to send my ecu out today for the exhale program (I have the UR 3" TB) but after reading this you are making me nervous.
This isn't going to be a perfectly sterile comparison, but it is the best we have for now. At least we will know what WORKS is all about.
There is debate on why WORKS refuses to present the public with a/f ratios. People from other camps think that it is because the car runs lean up top and WORKS doesn't want anybody to know that is how they are making the power. I personally don't believe this to be the case, but I want this debate to be over with. I will post the results good or bad.
Eric
I’m tired of wondering about this, so I made an appointment with Altered Atmosphere (www.alteredatmosphere.com/) in Maryland for next Friday the 18th.....
This the is main reason why I chose not to purchase the ECU flash yet. I give credit to some of you guys out there who took the chance and I look forward to seeing the results.
Originally posted by modvp
Do you mean next Friday the 15th August? What time will you be there?
Also, I believe this is where MachV does their EVO tuning.
Re: Re: Re: Works brain dyno with a/f coming soon
The ecu has programming in it that prevents it from being used in another car. I think it is the security from the key that will prevent it. If you swapped the ignition switch in the cars with the ecu it would work, but that is too much work for me. I will still get the pretty reliable results from this test. Not perfect, but we will at least know how safe the tune is.
DSM'ers would be in tough shape. We swap ECU's like Honda's swap engines.
54A-6
1. After the ignition is switched on, the engine control module sends a control signal and transponder read command to signal to the immobilizer ECU.
2. When the immobilizer ECU receives the control signal from the engine control module through the key ring antenna, the immobilizer ECU supplies a current and sends random number data to the transponder in the ignition key.
3. The transponder uses the random number data to derive an ID code, which is sent to the immobilizer ECU through the key ring antenna.
4. The immobilizer ECU compares the ID code that was sent with pre-reistered ID codes, and if it matches, a control signal approving ignition is sent to the engine control module ECM. If the ID code does not match (in the case of counterfeit ignition keys, for example), the immobilizer ECU sends a control signal denying ignition to the engine control module, preventing the engine from starting."
From looking at the chart in the manual, it appears the "immobilizer ECU" and the ECM are two seperate things.
But the manual does say something about having to Re-registering the ignition key...so maybe you're right. Darn. I just went full circle on myself.
I don't think it matters if Works wants you to or doesn't want you to... You can do whatever you want...i think.
I would like to see it.... I don't see any reason for a comparision... just the knowledge that if it is running too lean then in time you may have problems.....
If you run lower octane gas in the car, then were fairly hard on it, would result in problems? or is the ECU smart enough to adjust?... assuming it runs too lean up top.?
Re: Re: Re: Re: Works brain dyno with a/f coming soon
Originally posted by mayhem
Do you know anyone that has tried it? I think it'll work.
