anyone blown their aftermarket Lower Intercooler Pipe?
OK. It looks like it is important to have the supporting brackets that the OEM LICP has in order to keep the pipe in place. That is one of the reasons I have not changed mine (I still have the OEM). I was just poking to see if it is a common failure mode. I am planning to run 23 PSI and using an aftermarket LICP without a bracket might be an issue. Most of the aftermarket ones made of aluminum do not have the support bracket.
I also have an Injen LICP. It hasn't blown off at the LICP but the UICP came off once bc I had the clamp that came with it. Now I have T-Bolt so it hasn't come off yet but I'm still boosting with stock. On its way will be the Hallman cabin installed MBC, AEM WB O2, Swoosh boost gauge and oil temp gauge. I'll see if it'll blow or come off this time after I get it installed and tuned by 4WS.
I blew my Injen off 3 times in one week. 1st time the coupling was too short and the guy who installed it the first time didnt mention anything about it (jack***).
2nd time I didnt clean off the ends of the pipe and the oil/or whatever was on it probably helped it pop off.
3rd time got Fujita T-Bolts doubled up on each side and havent had any problems since.
I just upgraded to a AMS FMIC this past weekend and a new tune to handle more boost and everything is fine.
Key to preventing this is what everyone has said.
1. Clean the ends of the pipes with alchol, and the couplers as well.
2. Make sure the pipe is beaded at the end to help it stay on and make sure the clamp is behind the bead.
3. Use T-Bolts and dont be affraid to put them on tight its pretty hard to bend the pipes unless the T-Bolt you are using is too small then it might happen.
4. Double up on the T-Bolts just to make sure nothing pops off.
Hence my previous post. The original install was a botched job and it held for a while but eventually blew. If I did the install the first time I wouldnt have used such a short coupling. Now that it is hooked up correctly it doesnt have any problems and when in 6th gear I get a spike of about 26-27psi and tapering off it still wont blow off. Just my .02 cents.
