Injen intake, IC pipes with turbosmart BOV??
I need Ic pipes and so far this seems to be the best deal. after I found some pics of the IC pipes an Intake installed, I noticed that the BOV would be relocated. I have a turbosmart Evo specfic BOV and I wonder if anyone has run this setup without having any problems with the BOV hitting the fan shroud. Any input would be helpful.
I know the kit you're talking about. They're alright, but you could spend your money better if you want to concertrate solely on power.
- LICPs make some power: $150
- Buschur intake filter: $80
- UICPs don't really help much.
There you go. Already spending less money.
i have this setup and it hits the fan housing alot. its making marks on my bov and on the fan housing. def. imo dont get the injen pipes, licp always blows off at 24 psi.
well after reading the posts i will not be going with the injen kit. I have a intake pipe and filter kit already, so i just need the pipes. I am going to be running more then 24psi with alky so the injen is def out of the question.
As for the evo specific BOV comment, it's just the name that turbosmart uses for the BOV with the horn a little offset as opposed to thier regular dual ports.
