Trans fluid change
^ No you need a special tool if you want to change the ACD Fluid which you dont have. Basically it keeps the pump running to drain out the old while adding the new.
tc, trans, and rear diff changed normally. As easy as loosening any bolt
Its easy but you need a fluid pump (just a simple hand pump will do) to really make it quick and easy. I use bg synchro shift in the trans and diaqueen (mitsu) in the t-case. It takes me about 30min but I have a lift and a fluid pump.
DIY, we have a bunch of how-to threads, you should check them out. Its really easy I did it myself it took about 30 minutes. Did it in the garage. I spent about 30 bucks on tranny fluid (Royal Purple)
yup found it pics and everything
Now i have a NAPA, and AutoZone around me should i go with Royal Purple because that is what i was going to use but the shop said they use Redline fluids
I recently put amsoil in my tranny and it made a huge difference. much smoother now.
I know when I get my car soon this will be one of the first things to do. So I see people are using royal purple, redline, and amsoil... So which one does everyone recommend the most? I don't mind paying a little more just want the tranny to be fine.
