Hiss noise only at 10 in Hg ?
Just as the title states, when I am driving and hit 10 in Hg of vacuum I hear a hiss noise. That is the ONLY spot that it does it. Any other spots in vacuum, nothing. Any parts of boost, nothing. I have ran a thorough boost leak test and everything is fine. I am stumped on what this could be and thought maybe one of you have had the same thing before. Thanks in advance.
That was my original thought, but why would it only leak at 10 in Hg
Also , wouldnt it also show up as a boost leak, I thought everything in vacuum would also be in pressure when on boost?
i have a open element intake and already get a lot of noise. but i noticed a drop in power and increase in sound around 0-10 hg. i also noticed if im not at full boost, it will drop quickly, as well as not hold as high of a boost at wot.
so the other day i was inspecting my vacuum lines, and right off the boost controller in a vacuum line i found a pinhole leak that had threads coming out of it. after i fixed it, the extra noise stopped, my power increased(back to normal), and put me right back to 24 psi at WOT
