Still getting boost taper w Hallman MBC
1 Post
Is this normal to still get boost taper from 21-22 to 18-19 climbing to redline with a MBC installed? I did a boost leak test and i found one small leak and fixed it from a ICP coupling. Cant find any others. I thought when i installed this MBC it would have held a steady boost above 20 psi. Just need some input on others with this MBC
Yes, most likely anyhow. The underlying problem is that the stock turbo runs out of breath above 7K. Very few people hold over 20psi past 7K. Alot of people think they are boosting higher but it's probably just their gauge is off unless they've modifed the wastegate / turbo.
1 Post
Yeah i believe you b/c before i changed all my IC piping i DID hold 22psi steady then developed this problem. And that was with the ecu controlling the boost. So i thought maybe i was not remembering correctly or my gauge was off but apparently not
For the non believers...here is my recent dyno yesterday. You will see a quick spike to 23ish and hold pretty steady around 22psi to redline.
https://www.evolutionm.net/forums/sh...d.php?t=340236
Noize
28
Jan 30, 2007 07:41 AM
Atlmethevo
Sep 9, 2006 12:56 AM
