Works on the dyno
I believed the Works vs Vishnu dyno shootout would have been more to everyones' likings if it was held at a neutral dyno site, done on a stock Evo with dyno before and after mods for comparison sake, with various different configurations such as: Works reflash, reflash + Axleback exhale, exede, exede+ boost control, exede+boost+ catback, etc.
Yes, some configurations may produce more power than similiar config. from one tuner than from another, but i doubt that it would translate into significant performance advantages, bragging rights for sure!
Another side of the matter is that Works and Vishnu appeal to different clients.
Works with it's 3 yr warranty, stealth configuration, excellent client feedback with handsoff no tinkling no thinking just stomp on it and go conservative approach, versus Vishnu with it's piggback unit with adjustable boost can further be refined through fine-tuning by Client and /or Shiv himself gives it a theoradical power advantage, although when you add in dyno time and costs, can easily cost at least twice as much as the Works reflash.
As you can see, it's different stokes for different folks!
By the way, thanks to the folks at Vishnu for their wonderful food!
Wilson
Wilson
Originally posted by wilson1
... although when you add in dyno time and costs, can easily cost at least twice as much as the Works reflash.
Shiv
Originally posted by shiv@vishnu
But the end results/gains aren't necessarily the same.
Shiv
Shiv
Originally posted by n00dle
It's only misinformation if you interpret it to be. The original poster just posted a graph without detail. No one was trying to downplay anyone. It's all in your heads. Some times you have to do your own homework to find the truth, not heresay on some board.
BTW- I realize that the guy who originally posted wasn't necessarily trying to be malicious, and that he was just trying to provide some info to other EVO owners. He picked a pretty volatile and provocative subject though, and should realize its going to get a wide variety of response's. My apologies to him if it sounded like I was coming down on him personally, as its the actual info/dyno chart overlay that I find concerning.
The last two sentences of your above post are dead-on accurate. The problem is that more than a few people who own EVO's on this board, are first time turbo car owners and are trying to learn as much as they can about different tuning options.
Understanding the details between the lines isn't always a simple task "of doing your homework". What ends-up in many peoples heads may be an unwarranted negative bias against an excellent product because they rely on the "experts" opinions.
The argument referencing the other two stock EVO dyno results against Wilsons car is pointless as a method for determining the value of the Works tuning products. There is really no way of knowing where Wilsons car would have baselined at stock on the Dyno Dynamics Dyno prior to installing the Works mods.
The bottom line is that the only true way to validate the performance gains of either the XEDE or the Works tuning solutions in a fair comparison against each other, is to dyno test using a common stock EVO as a baseline car, and then methodically testing and documenting each solution on the same day on the same dyno using the same process.
This of course, did not happen, and as far as I am concerned relying on any of the random dyno results from different cars as gospel, is like taking biblical scripture out of context. It can be used effectively to promote ideas and personal views, but at the end of the day doesn't necessarily represent the truth.
Sorry for the long post, and for beating this dead horse one more time. I truly do not stand behind either Shiv or David on this one, but just wish a meaningful comparison could have occured for the benefit and enlightenment of the EVO owner group in general.
N10S
Originally posted by umiami80
Was the guy running regular gas or something? A stock Evo should have 230WHP on 93, and with the WORKs mods a nice 260WHP, I don't get it.
On a typical dyno, such as a dynojet, you are correct. Most stock evo's typically put out 220-240 whp, and as u stated above, 25-30 more with the reflash.
However, Shiv's dyno is a dynometer, and dynometers typically show approx. 20-30 whp less. Moreover, a stock evo @93 ocatane will usually put down 195-205 whp.
