Help Please Boost Leak
Ok i setup the car for testing all is well with the setup....i proceeded to pump air into it and INSTANTLY i heard air/hissing from the Intake mani. area......I tried to reach around but by the time I reach it was finished.....it is loud enough or it seems as though loud enough to feel with bare hands.....Im wondering my car even ran let alone ran at 25 PSI........im going to continue looking around while i wait for responses, but if you guys could pop off suggestions on the line I cant see that would be awesome!!! Thanks also I dont have time to search....sorry!!!
PLEASE HELP, serious posted please THANKS!!!
![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
ok neverfails after i post i seem to find it
Not sure which it is but when i touch or move what feels like a "f" connector behind the Intake Mani.....can not really see it to get a visual
ok i found two so far
the major was back-left motor under intake mani area,
the second I havent seen yet but it sounds like the throttle body area if not behind the intake mani.....I have already replaced my throttle body seal before....could I need more? this is little over a year ago....
wow thanks....lol It feels like it coming from the TB Coupler clamp/mouth of the TB, or maybe even the Coupler may have a PIN hole in it....I lose about 5lbs of air every 5-10 secs....counting mississippi style.......
The first Major one was the egr vacuum reg....line it was dried out and had split
check the connection by the egr valve...to see if the throttle seals are bad again(you should have the works seals in there) apply pressure and adjust plate with hand, if air pitch is different then your seals are bad, again. WHen working behind the intake mani, i always take off the upper strut bar ...gives you better access and visibility. 14mm nuts for the strut. Make sure you zip tie the hoses in the future. All the hoses off the back of my intake many have zip ties...
Off to walmart to get a new spray bottle, I just stepped on mine trying to get to the PC lol......
what started this deal was that my BOV wasnt releasing right.....My car was pulling 24-25 spiked PSI....no running probs at all.....so i didnt think anything was wrong.......welp goes to show you you shouldnt doubt!
still not releasing right....could the seals in the TB affect this? it is a really slow leak.....I can literally count to almost ten before the guage goes to zero from 10 psi
yes it will leak like that. I would remove the coupler to the tb and adjust to make sure the seal is tight there. Also, check the egr valve again...nipple is right below the TB. Those are pretty much the only 2 connectors you should have.
Remember, the car will force air through the motor until the set boost is reached, or as close as possible depending on the leak. The car has to work way harder for the same boost...power gets affected, a/f gets skewed.
Where did you get your TB seals?
