carwash and wideband stopped working????????
Old May 2, 2008 | 01:50 PM
mitsuboost30's Avatar
Question carwash and wideband stopped working????????
like it says i just washed my car and the wideband stopped working any suggestions of where to start fuses etc etc..
help please
thanks guys
-Chuck-
Old May 2, 2008 | 01:58 PM
com on guys chime in
Old May 2, 2008 | 02:13 PM
FloopyDisk's Avatar
Check your connections first and foremost.
Old May 2, 2008 | 03:15 PM
Chemwarrior's Avatar
I would suggest starting at your sensor and working your way forward from there.
Old May 2, 2008 | 03:19 PM
Evo9tunerz's Avatar
Did you wash the car yourself?
Old May 2, 2008 | 03:33 PM
Evoluvin's Avatar
yes check the sensor and make sure its still in the downpipe or where ever you taped in at, make sure its still in there and make sure the wires are still attached to the sensor, i would just check every single wire first and then go from there, if you dont see anything it could be the fuse
Old May 2, 2008 | 04:37 PM
Thanks guys!
Old May 3, 2008 | 03:46 AM
W_evo8's Avatar
what brand wide-band and does it still turn on but the reading is wrong or is it off completely?
Old May 14, 2008 | 09:28 AM
Aem Uego
no it just completely doesnt work
its like a month old
Old May 14, 2008 | 09:32 AM
kanyonkid's Avatar
I have this problem, for 2 days it worked perfect, then out of nowhere it stopped working, i have the innovate lc-1 and it comes with that red light u know, and the light blinks like normal when u start the car then the light stays off and my gauge either reads 15.1 and doesnt move, or 7.4 and doesn't move....
Old May 16, 2008 | 07:12 AM
Any ideas guys comon
i looked at fueses tried rewireing it.... nothing....
Old May 16, 2008 | 07:19 AM
sharkm87's Avatar
may have shorted...did you take the gage completed out the car and give it power to see if it comes on at all
Old May 16, 2008 | 07:22 AM
ehh not completely out of the car but pulled it out of the bezel
Old May 16, 2008 | 07:37 AM
jmelocik's Avatar
+1 checking the sensor. Also I would check were the wires go through the chassis and make sure they didn't rub and short out there. Then check the ground to make sure it's still attached. If all else fails get someone else who has the same kind as you and plug there gauge in and see if it works. If it does, send your gauge back to AEM and ask for a replacement.
Josh
Old May 16, 2008 | 10:00 AM
EvolNinja's Avatar
I washed mine the first time at the car wash and it's fine. I have the same wideband. Wing off and antenna is off too
