Loud lifter noise
Old Oct 6, 2010 | 10:42 PM
AboodsEvo's Avatar
yeaah I agree on the oem filter. Same happened to me when I changed to OEM and that ticking annoying sound was gone! and im running stock cams:P
Old Oct 7, 2010 | 07:54 AM
barneyb's Avatar
Originally Posted by thomas.featsent
I had some lifter noise and it was because of the oil filter only oil filter you should use on evo is the oem which I didn't know. Didn't think it was a big deal. But sure enough got a oil change and put the oem one in and no lifter noise.
I'm at about 70K and no lifter noise. The last OEM oil filter I had on the car is the one that came on it from the maker. So, I have hard time believing the OEM filter is the secret. I do try to use a quality filter.
Old Oct 7, 2010 | 10:33 AM
4g63Moon's Avatar
since ur planning on installing the cams and head needs to come off, why not throw in a arp head studs and replace the lifters if they're bad
Old Oct 7, 2010 | 11:41 AM
sobo's Avatar
You guys cant be serious about an oil filter... can you?
My car has seen nothing but the ****tiest oil and filters money can buy. I run 272's and I dont have lifter tick. I have almost 80k miles on the motor.
Bleed your lifters, if thats no good. Suck it up.
Old Oct 7, 2010 | 12:27 PM
EVO8STI's Avatar
we are not complaining. just wondering why this is happening, i just changed my oil and used a different filter and heavier oil and i got ticking. kinda weird. you don't just suck up and let something possibly bad happen just so that i can throw more money into my car... that is ignorant.
i dont suck up when i get a tooth ache i go to the dentist and have it fixed, other wise my tooth will rot out of my head.
Old Oct 7, 2010 | 12:31 PM
sobo's Avatar
Some things can't be fixed or aren't harmful to you car though so your analogy doesn't apply.
I'm just saying, evo's are known to tick. Assuming you installed your cams correctly, you should be fine.
If not, it's nothing an oil change will fix. Oil prevents damage, not fix it. You should pull your valve cover off and inspect for broken parts if you are that concerned.
Old Oct 7, 2010 | 12:34 PM
EVO8STI's Avatar
me personify have never heard of lifters just start ticking out of the blue for no reason... but you could be right, it could just be the nature of the beast.
i just thought i was odd it started immediately after i did my oil change.
Old Jan 14, 2011 | 03:49 PM
BoosTyEVO's Avatar
EVO 8 possible lifter tick ? with video
evo 8 with no cams i think the sound is worse before its warmed up fully , but here is a video of it fully warmed up at idle , is this a normal amount of noise or something to be concerned with am I just paranoid lol I'm not even sure if it is lifter tic
<iframe title="YouTube video player" class="youtube-player" type="text/html" width="640" height="390" src="http://www.youtube.com/embed/dlnMg5dHLkc" frameborder="0"></iframe>
if that doesnt show up here is the direct link
http://www.youtube.com/watch?v=dlnMg5dHLkc
Old Jan 14, 2011 | 09:28 PM
kikeixmr1982's Avatar
i got to try that on mine then
Old Jan 14, 2011 | 09:33 PM
it sounds just like mine but i got cam's ..
Old Jan 15, 2011 | 12:26 PM
BoosTyEVO's Avatar
i found out its fine here is a video of true lifter tick u can hear how pronounced it is
http://www.youtube.com/watch?v=aCKyT...eature=related
Old Jan 16, 2011 | 09:14 AM
kakarot305's Avatar
Mine also started to make a little noise after 8 passes on the dyno but now the noise is gone could this be the oil getting too hot Im using 10w-30 mobil 1.
Old Feb 4, 2011 | 06:27 AM
SRTRaceR04's Avatar
Mine has that light tapping like the first video, but mine only does it when the car is fully heated up.
And it's random. It's not like a steady pattern. It's like tap, tap, nothing, tap, tap, tap, tap, nothing, nothing,tap, nothing... etc. I wonder if this is the same thing?? The car has quite a bit of valvetrain noise I wonder if my valvetrain is ok as one shop kept revving the stock head (minus headstuds and cams) to 8k on a 2.3L.
Old Feb 4, 2011 | 08:16 PM
achilles3000's Avatar
All evos do this when having big cams and upgraded springs more so on a stock motor.It normal guys as long it's not piston slap or a floated valve then your good.
Old Feb 4, 2011 | 08:34 PM
TxFAkuma's Avatar
WOW this thread was very very very helpful to me... i started hearing this noise 2 weeks before i stored my car for storage for the winter...and now threw the whole winter im sitting here thinking my evo is all fu**ed up. Im actually glad too hear that its normal.. Umm the noise im getting is the one in the first video.. and it makes that ticking noise when the car is warmed up only.. and WOW in parking ramps its LOUD! also drive threws against the wall!
As long its normal im fine with it then.
Quick Reply: Loud lifter noise
