Emission
Emission
Hi guys! I just want to know if you have passed the emission test on your Evo's.
I mean putting aftermarket parts would affect your emission result.
Does anyone has a problem with this before?
Alot of parts can affect the results. Luckily im in a state that does not do emission testing.
No, I dont have a check engine light. I'm just worried coz a friend of mine just told me if you got no more cat and stock ecu then there's no way you can pass emission.
u have to have a cat on stock ecu. cause they hook a computer up to your obdII port.
if you dont have stock ecu then they cant talk to it so then you get a fail. same goes for cat its a federal thing.
With obd2 emmisions testing the car should pass as long as the check engine light is off. If you don't have a catalytic converter, you will very likely get a cat fault. This can be easily fixed using a spark plug non-fouler (hint,hint search). That should be the only emmissions issue that you should ever have to deal with.
dont even dare to try to pass emissions without a cat, with or without a cel fix. Why well because its a EPA law and you will get a very hefty $2500 fine.
always have a cat installed, just take it off afterwards.
The problem is they already cut my cat so how can I put it back on?
