this guy needs help fast...
I want to say cam angle sensor, but of course thats only because it happened to me......did the code catcher even tell you what that code says? We need more info abot the code......The answer lay's in between the code CEL
You can either have it reset, or wait for a few more cycles of starting and restarting and as long as the ecu doesn't read a misfire code again, it will reset. Also, did you happen to pull the MAF plug?
