is it normal for checkengine light to go on w/hfc
It should pass smog even with the sniffer, since ur running leaner HC and CO will go down and NOx will go up but since our cars are all wheel drive it doesn't need to go on the dyno therefore it wont measure NOx...
and can someone tell me if ill pass emissions in NY with the antifouler?
offtopic: just got done swaping the three factory oil,volt,boost gauges with the radio it was very easy took me about 25mins and i moved the boost gauge to the left side so its easy to see. it looks good i like it
The anti-fouler has nothing to do with a sniff test. It depends on your catalytic converter.
