is it normal for checkengine light to go on w/hfc
#31
You lose performance by not having your car tuned for a free flowing exhaust. Don't worry about the anti-fouler. Make the DIY job, install it, remove neg on your battery and turn on your dome lamp til power is drained from your car, reconnect and VOILA! No CEL.
#35
The anti-fouler/O2 sensor? Yeah I did the same, but only because with it on my test pipe, the O2 sensor had very little clearance from the ground. I relocated it to the Evo VIII bung spot in my catback and I'll use the TP bung for a future wideband or something. (Yes I know I'll have to rotate it to less than a 3 o' clock position to avoid moisture)
With a HFC, you'll get a CEL sometimes. No worries. I understand why a lot of guys use HFCs, but I'm going to have to recommend a test pipe. They sound heavenly when making pulls under highway overpasses. [It is like, if you're going through the trouble, do it right with the most free-flowing component you can the first time.]
#36
I agree....I use a catless downpipe. One a year pull it off, slap on stock exhaust and go get sniffed....the trouble is worth it.
blaze_125
Lancer Troubleshooting
Dec 2, 2011 09:52 AM
