Safe boost leve for a stock internal EVO 8
Old May 17, 2008, 11:37 PM
racer135's Avatar
What would be the max boost safe level for a stock internals evo 8. Mods on the car are: Works drop in filter, Works TBE Catless, Walbro HPFP, MR DV, ECU Boost Control with GM 3 Port. All the engine internals are stock including the studs. This is a daily driver and not used at the track. This is assuming a good tune on 93 oct pump gas.
racer135 is offline
Old May 17, 2008, 11:40 PM
Wicked E's Avatar
36 psi to the search button...
-E
Wicked E is offline
Old May 17, 2008, 11:47 PM
racer135's Avatar
I have been searching but I am looking for speak/surge and hold numbers.
racer135 is offline
Old May 17, 2008, 11:58 PM
thatguy's Avatar
24-25 psi spike sounds reasonable with good parts combo.
thatguy is offline
Old May 18, 2008, 12:20 AM
eponti's Avatar
I won't go pass 25 psi without the studs specially if it's a DD.
eponti is offline
Old May 18, 2008, 12:50 AM
4WS Tuning's Avatar
23ish is approx where you want to be with your mods.
Cheers!
4WS Tuning is offline
Old May 18, 2008, 12:54 AM
4WS Tuning's Avatar
With a good tune, maxing out the stock turbo with factory head studs isn't an issue. You really dont need them. If u like wasting money I have them for sale for 200 shipped ;-p LOL
drive your car without fear of damage. Keep the knock under control and you have nothing to worry about.
Cheers!
Old May 18, 2008, 05:44 AM
racer135's Avatar
Thumbs up
Cheers!
Is the 23 PSI the peak/surge boost value I should set for or the steady state pressure? Setting a 23 steady state value will be like a 24-25 PSI overshoot.
Is that OK for a stock EVO? Or should I go for a 23 PSI overshoot with probably about a 21-22 PSI steady state? Th!anks for you help!
racer135 is offline
Old May 18, 2008, 05:51 AM
warp9's Avatar
Go for the 25 peak as it will drop to 23. By the way, some people push 30 psi on the stock motor with no problems.
warp9 is offline
Old May 18, 2008, 05:52 AM
warp9's Avatar
-E
warp9 is offline
Old May 18, 2008, 06:00 AM
MREvolution's Avatar
i would stick around 22-23 with stock internals.
MREvolution is offline
Old May 18, 2008, 06:14 AM
racer135's Avatar
Again please specify if you are talking about overshoot or steady state. Or just state both.
racer135 is offline
Old May 18, 2008, 06:45 AM
mpevo8's Avatar
its all in the tune. if you have a good tune than you really dont have anything to worry about. but for you i say around 23 psi is safe...with a good tune. Im tuned at 25psi on 93 octane for two years already. IVEYTUNE FTW !
mpevo8 is offline
Old May 18, 2008, 06:56 AM
EvoPooPoo's Avatar
Cheers!
Just log your car and send to 4WStuning... customer service is #1.
Tamer will take good care of ya.
Then turn up the boost to 23psi!!!!!
EvoPooPoo is offline
Old May 18, 2008, 07:02 AM
alloutDSM's Avatar
you might want to invest in some meth if your looking to go over 26PSI IMO
alloutDSM is offline
Quick Reply: Safe boost leve for a stock internal EVO 8
