Weird Sound
it might be the timing belt. from everything youve said, i am fairly sure it is. my car made the same noise, same area, same low rpm...i took is to scmitsu and they said there are some defective timing belts out that need to be replaced..i took it to them, they replaced it 4 free and the noise went away....check it out......
yea i kinda have the same noise going on.... it seems like.... its coming from the area of the timing belt.... but when i bend down by the passenger side front wheel i can hear it a lot more... the noise isnt always there.... its at idle...and cruising in first gear in like a parking lot or something...
yep, thats the sound, seriously, first thing 2mro call your mitsu dealership and tell them. if they dont say anything about the defective timing belts out then there tryin to con u...
i somewhat dont think it is the timing belt though...sometime tomm i will record it... and post the video up
yea im a little doubtful that the timing belt could cause the noise im hearing like i said i will post a video up today and i'll see what everyone thinks.
the best way i can describe the sound that im hearing is.... think of the sound that our lifters make.... a little bit more high pitched ... and its paced with the sound of a pulley... and i can hear it from the top of the engine bay but its louder down by my passenger from tire... and i can also hear it when im low rpm in 1st gear....i was thinking maybe its the bearing for the alternator? or something like that...ive read about them being a problem on the forum before.
Emperor666
17
Apr 10, 2007 05:52 PM
