Misfire !!!
Misfire !!!
Hey guys I need help!!! I just put ngk spark plugs in and the car has 74k. I tried going for emmisons but i have a check engine light and it is a radom misfire in all cylinders. anyone has any idea why its doing this ?? Also and for low efficency in the catylic converter. any ideas ??
thanks
sakib
thanks
sakib
did you have this could before you put the spark plugs in? you probably have a bad cat did you ever replace it in 74k miles if not its bad! "you should you should get a compression test done just to see how strong your engine is at 74k but that has nothing to do with your problem" do you have any modes?
