Car stuttering between hard shifts
My mods were AMS 3" TBE, Cone filter, MBC, tune
I recently added a AMS FMIC, Ported exhaust manifold, cams and 02 housing and got it re-tuned at AMS yesterday.
It drove fine all the way home (150 miles), but now when i get on it and make a hard shift at 7K+ RPM's it falls on it's face once i get into the next gear, then takes off again. It's now doing this every time in every gear everytime i get on it.
So basically if i floor it in 1st gear, it's fine, i shift into 2nd quickly, floor and it stutter's you hear a faint pop/pop and it takes off again.
Any ideas?
And i feel the stock bov is fluttering more than ever at part throttle (I thought maybe it was leaking??).
This is an 06 Evo with 25K miles if it matters.
Any ideas?
It sound like my car before i changed out my sparkplugs. Mine stuttered shifting between 6-7K rpms when getting on it. Other than that it was driving ok. I was using Denso IW-22s for about 25K miles and I replaced them with the same sparkplugs and the car drives fine again. I might also change out my spark plug wires soon.
But definitely call AMS and see what's up. I'm also curious to know what's going on.
same thing happned to me wen i would make hard shifts after my tune....it was not enough fuel and was running to rich....call ams and tell them.....or do u have a bigger fuel pump??...its deff a fuel problem i had the same thing
I was having the same problem, so I check the spark plugs gaps it was too high.
I reduce the gap the the "miss" went away, occasionally i still get it, so I went and try the copper plugs everyone was talking about, and I was surprised that copper actually perform better than the iridium!! Copper has better conductivity than iridium, check the periodic table.
stock fuel pump, i'll get a hold of ams today. I'm sure AMS will take care of it, it's just that if it's something simple, i don't want to waste a drive back there.
Any ideas?
Any ideas?
dhahlen
Lancer Troubleshooting
84
Mar 19, 2012 07:44 PM
car, evodom, evolutionm, evom, hard, injection, methanol, mitsubishi, raider, shift, shifting, shifts, stutter, stuttering
