Selling my evo8 soon......
Originally posted by M3lachsilber
GREAT!
PM me yer credit card number..
GREAT!
Make sure you post it in AutoTrader or some mag similar that gets national coverage. One of the local speed shops down here had an Evo and sold it b/c the owner left to go to FL. He sold it to a guy somewhere up north. He had around 4K miles and it was for sale for $26 I believe and he had the Buschur turbo-back, MBC, intake and maybe one other thing.
Good luck in selling it.
Originally posted by Diesel
good rubber...?
good rubber...?
Originally posted by zyounker
What i ment by good rubber was that they don't have 9K miles on them cause the stock tries would be completely bald by then...
My $0.02.
Originally posted by Max Rebo
For you skeptics out there -- from what I've heard/read, the Falken Azenis are very good tires, and nowhere near as expensive as the stock Yoks. IMO, the Azenis isn't much of a downgrade, if anything at all, considering the Evo has AWD. The sidewalls are very stiff and they stick like glue, even on heavy-a$$ FWD cars like my GTI VR6.
My $0.02.
My $0.02.
Thanks for the backup, but the truth is they are not as good as the stock rubber i found this out because i tried them out.. They are not bad though, just a little harder and the sidewalls actually are not quite as stiff as the stock rubber was.. This actually suprised me..
-Zach
Has anyone used the S03's? I may get them or the stock tires but dono what is better. Cost is not a issue.
-Zach
-Zach
I think the Stock rubber is probably better. Unless you go with some yoko A032(or the new A048) or maybe some kumo V700 it is gonna be hard to be better i think..
Falken Azenis are very good tires...
If you ever attend an autox event... you'll probably find that 85%
of cars running street tires are probably Azenis (and the rest
15% probably just can't find the right size Azenis for their
car)...
Not saying Azenis is better than stock Advans.... but just stating
what I've observed... (though maybe with a bit of exaggeration
car)...
Just Moving on to other cars.. I have always been a rotary guy, so i will be finishing my RX-7 and picking up an RX-3.. i think i will also be picking up a 323 GTX for rally.
-Zach
-Zach
Originally posted by ishi
They still have 12A over there?? WOW very hard engine to find over here. Or you gonna do a swap with FC engine harness??
No, i will be building an RX-3 with a S5 13BT. It is fully built street port that is also dowled. Running 9:1 compression.. I am also gonna run a GT35/40 turbo which should do ~480RWHP@20psi (on a dynojet, which read high)
-Zach
