Some weird problems with my evo need serious help!
Well my car was running fine today and then all of a sudden after i shut it off it wouldnt start again....
There are several weird things going on, when i turn the key nuthing happens...all the dash lights and the clock light up but nuthing when i turn the key. The only thing i hear is the fuel pump. Also when i turned on the lights the only lights that didnt work were the 2 side lights on the fenders and the one driver side headlight....WTF.
Problem number 2:
After i got the car started by pop starting it while driving in EVERY gear when boost reached 0psi or around 3000rpm the car would stutter real bad, the motor would shake and make a fast duhd.duhd.duhd sound. In order to get out of this i would have to let off the gas then press it again but then after a few seconds it would happen again. Something isnt right
please help!
Problem number 2:
please help!
check the spark plugs.... i had a similar problem when i tried those pulsplugs..... but thats the only thing i would know of to check... the electrical is weird tho... but the stuttering at 0 sounds like spark plugs
https://www.evolutionm.net/forums/sh...d.php?t=342599
A water leak in the electrical system can do strange things
side marker lights were turning on, blinkers stuck on, wipers magically turning on, car not wanting to start etc...
check the rubber grommet with the main wiring harness in the drivers fenderwell that goes into the feet area above the fuse box. mine was hanging out and water was just dripping down there from the stupid drain Mitsubishi put above wiring loom.
I took out the connector and hard wired all the wires that were corroded.
Have Fun!!
had the same symptoms happen to me about 3 months ago.
Have Fun!!
Have Fun!!
so your car also wouldnt start? it doestn even try, all the dash lights are on and such but the car wont even click turn over or anything..all u hear is fuel pumping. Nothing turning.
One of the side lights on the fender was on really dim for a few seconds when all the lights were off i was like wtf.
thanks ill check tomorrow
I would check the white plug connectors in the drivers side foot area just to the left of the dead pedal.
alright thanks...im at work until 4 and the cars home so ill check it when i get home. Any other things i should check over...it doesnt seem like a starter problem or could it ?
UPDATE:
The pigtail that goes to the starter fell off...that was my starting issue....BUT
with the car on the left headlight still does flicker and the SRS light remains on.... i only hardwired 2 wires so far..( the bottom black plug with the 2 green wires in it.)
any more suggestions before i do the other wires?
Thanks guys for your help....so this is what was wrong..
The pigtail came undone on the starter(starting problem)
AND
took the fender liner off, followed all the wires going from the kickpanel area to under the hood and found the bolt that GROUNDS the lights and wiring harness was unbolted and on its last couple of threads.
Tell me how these 2 things happen in the same day at the same time? lol
So to anyone with the similar problem check this ground!!
AND
