Noise, Need Help Please!
i have a odd noise that is driving me crazy because i cant figure it out.
when taking off from a dead stop i get a kind of knocking noise. its between 4 to 8 knocks and its done until i start driving from a dead stop again.
last night i noticed its only at 1500 rpm and only when the car is driving.
i can sit and hold rpm at any point between 1000 and 2000 and it wil not make the noise. also on a cold start the rpm sits around there and no noise.
i can also coast the car in 1st and on de-accel dropping on and below 1500 there is no noise but when i hit the gas the knocking comes back.
to be honest its only really there when the car dips in rpm when your feathering the clutch out besides the whole coasting below 1500 and hitting the gas
im stumped
anyone have any ideas?!
im stumped
![Frown](https://www.evolutionm.net/forums/images/smilies/frown.gif)
I have the same noise too.... Does it happen only when taking off slowly like under normal driving circumstances? It is also noticeably louder when turning left or right while taking off slowly. I was thinking something like a wheel bearing
![Confused](https://www.evolutionm.net/forums/images/smilies/confused.gif)
yes exactly! i had a friend walk next to the car he said its coming from front driver, it sounds to me like right rear. ill check my bearings but im pretty sure its not that.
i do have odd ball tires and was wondering if that was it.
to answer the other questions im a bone stock evo with 23k miles
stock clutch stock everything
well i dont feel nothing, just a annoying noise. i think ill get under the car tonight and check the drive shaft. now that i think of it that sounds like the most logic answer. thanks for the idea!
i dont remember checking clearance when i changed the oil last and i dont have much time to get under the car cuz of crazy work hours,
just trying to get ideas so i can check alot of things at once....
It might... cause when i changed out my stocker for the HKS DP I noticed the stock one was pretty close. And now the 3" aftermarket one is waaayyy close. If it is that either spacers on the tiebars or motor mounts?
im hearing it on take off at exactly 1500 rpm everytime in 1st gear, doesnt matter if its a turn or not.
