Remove front and rear bumper
1 Post
one screw on each wheel well, two bolts up top near the radiator along with two pop in plastic pieces, and then pull the two tabs off in the front and take those two bolts off, and walla!!!....
OH and dont forget about the pain in the azz brush/rain gaurd underneath the engine bay......GL
1 Post
on the rear the bumper nuts for both sides and the back are in the trunk. The sides are behind the little access panels and the rear's are under the plastic trim just inside of the trunk lip where the latch is. Not hard but the front also has those plastic retention clips on each side once all the other hardware is removed from the sides you just pull down and they pop out.
Josh
Josh
