Water on passenger side? Help...
Hey,
Well yesterday was a hot day and I was driving about 2 hours each way. On the way my g/f noticed the floor was getting wet, at first I just thought it was some condensation but soon turned into a kitty pool of water. Lucky I had towels in the trunk to contain it until I got home. It seems to be leaking under the passenger side where you put your feet, when I go around turns I can hear the water slosh and just pour out. I noticed under the car there is no water spots like usual so I'm assuming it has something to do with that.
Anyone have any recomendations, looks like the condenser drain is clogged or something. Pictures would be great, I leave for Iraq next week want to get this fixed so I can use the A/C.
Thanks!
Brett
Thanks!
Brett
There are a few threads about this--- it seems as though a grommet is the culprit, accessible by removing the inner fender well. It isn't properly sealed when the gauge package is added in port.
the a\c drain will make it look like that i had that problem. i put an air compressor to it blew in and a ****load of water came out. its worth a try and it only takes a min
