bumper lip clips
Go to the dealer.
or from lancershop here: http://lancershop.com/customer/produ...1&cat=0&page=1
Or go to http://www.mitsubishiparts.net
Also, you might wanna search around these forums..
I think I remember someone finding different ones [honda maybe? idk?] that worked better and weren't so hard to put on/take off.
you can easily find them for cheap at your local autopart stores. i had two break on me, i cant remember which place i went to but it was cheap cheap and i have never had a problem with them
I'm having the same prob where the lip routinely falls out of place (right in front of the RT wheel). The clip looks ok, its the flat part where it connects & contacts the lip has separated. There are two small points on the lip bodywork that correspond to two points on either side of the clip where it once was attached and the parts line up.
I'd like to take the clip off, and try a dab of epoxy to put it back on the lip then fasten the thing back on. Should this work?
2010evoxgsr
Jun 22, 2017 11:41 AM
Liker135
Mar 10, 2012 05:12 PM
point&shoot
11
Jan 30, 2007 12:35 PM
Andrew LB
23
Aug 7, 2006 09:54 AM
