loss of power.
Old Jun 28, 2008 | 11:56 PM
pjb00stin's Avatar
loss of power.
hey
I have my evo viii.when I first got it,it was starting to spool right before 3000,like at 2800.now,its hitting at around 3200,and it feels like its boosting very low.
this happened after I wet my turbo with water because radiator fluid got on it.but some people said it wasn't the problem.could this be a messed up bov?its the stock plastic.any ideas?thanks!
Old Jun 29, 2008 | 12:05 AM
EvoJoeIX's Avatar
how much boost are you getting?
Old Jun 29, 2008 | 12:11 AM
Odenl0ki's Avatar
Are all of you IC pipes connected and sealed properly? Do a boost leak test. Do you have a boost gauge?
Old Jun 29, 2008 | 12:19 AM
pjb00stin's Avatar
I don't have a gauge,but it should be boosting stock,like 19 psi?I can here the turbo spooling but its spooling slow.how do I perform a boost leak test?
Old Jun 29, 2008 | 12:21 AM
pjb00stin's Avatar
I don't have a gauge,but it should be boosting stock,like 19 psi?I can here the turbo spooling but its spooling slow.how do I perform a boost leak test?and yes,the ic pipes are all in good shape
Old Jun 29, 2008 | 08:12 AM
gsrboi80's Avatar
Search boost leak test. Your will then be enlightened
Old Jun 29, 2008 | 11:38 AM
pjb00stin's Avatar
could the plastic BOV be the culprit?
