Stock Undertray
Stock Undertray
Has anybody found an alternative to those screw type plastic rivets that hold the stock undertray in?
I was looking to find some pop type plastic rivets (where you just take the head of the screwdriver and push it in the center part of the rivet and pit pops out).
Anybody found the size/place to get them that would work?
I think using those rather than the screws that strip incredibly easily would make it much easier to remove and put back the stock undertray...
You can find some at autozone for pretty cheap, well cheaper than oem. It's on that rack that spins around and has other types of screws. Make sure you bring one with you so that you can compare them before purchasing.
I purchased a bag of new clips from Napa, take a old clip with you for matching. A better clip design or for faster removal, the Ford clips would be a better choice. They are designed to be removed with a panel removal tool only.
https://www.lancershop.com/customer/...ctid=581&cat=0
