Debating on next mod.
The intercooler pipes that come stock on the car and the couplers are **** imo.
I would highly recommend you do a LICP, FMIC while you're at it since you have the bumper off and the upper intercooler pipe and an intake well before you do cams.
Once the boost in the engine goes up, power goes up. The stock pipes and couplers are not good at all for higher than stock boost levels. I just installed a full Injen I/C kit in black with brand new couplers on super tight. While I was at it, I also installed a ForgeRS recirculated BOV, and a Forge Manual boost controller.
I am not even thinking about doing cams until I have all the following done:
LICP, UICP - Injen Intercooler piping - done.
FMIC - AMS FMIC - done.
BOV - ForgeRS Recirc. BOV - done
MBC - Forge UNOS MBC - done.
Full Turbo Back Exhaust - Megan Racing Down pipe, test pipe and rare black Cat Back - DONE!
Boost / Wideband / Lambda - Zeitronix Wideband - doing that this week.
Tune. - Doing that in a few weeks @ TTP.
THEN maybe I will get cams on the intake side... and another tune down the road...
Make sure your precautionary mods are done FIRST prior to power making mods. This prevents failures and blown engines and what not...
yes i no about the tune. i havent installed the walboro or the mbc yet i already have the tactrix cable and have been in touch with 4ws to set up a day to start eflashing my for now
so iv herd from chaotic. i was really relying on them but i guess fmic is gonna be what i go with unless anyone has any better ideas. i was also thinking meth but i didnt want to anything to that extreme till a little bit more down the road
I'm aware peak numbers mean very little...but the amount of torque that is gained isn't that impressive
imo the amount of torque you gain is not worth the cost of cams
and i respect your opinion
but going with fmic and piping, your probably not even gonna gain as much as cams will net you
and you can get more then 10whp out of mivec cams....
this is all up to the OP, i think he needs to look and see what his plans are with the car and then go from there
Ill say it again, reinforce the I/C piping and reduce the restrictions of a stock Evo first before you do power making mods...
I/C piping, recirculate a better BOV or the stock DV, get an intake and exhaust THEN maybe cams... the intake/ Intercooler piping & exhaust are going to be restricting what benefits your cams would do if you didn't do these below first...
Cams should be last before you do at least these, IMO:
Intake
Full TBE
I/C piping
FMIC
BOV or use the stock DV
MBC / EBC
TUNE
Then when you are bored...
CAMS / CAMS & METH
TUNE
Intake
Full TBE
I/C piping
FMIC
MBC / EBC
TUNE
CAMS / CAMS & METH
TUNE
you should really read this thread before asking these types of questions.
https://www.evolutionm.net/forums/sh...d.php?t=330085
i just came off of the same situation but i have no clue of what mods you have done you your car right now..
make sure you have your tbe, intake, 255 fp... and if you do cams might want to put in some arp headstuds for insurance.. and get a tune.
your other question about uicp, ets sells one kinda pricey i settled for a DEJON TOOL uicp works perfect.. dont get much power outta that anyways.
keep the fmic for a bit it hold perfectly fine its just ugly..
class of 08!
class of 08!
mantosride
Dec 27, 2009 10:48 AM
krisdlm
10
Nov 16, 2009 06:41 PM
mantosride
25
Sep 21, 2009 08:54 PM
