View Poll Results: How long does your clutch last?
Clutch gone at under 5k miles.
75
11.59%
Clutch gone at under 10k miles.
80
12.36%
Clutch gone at under 20k miles.
58
8.96%
Clutch gone at under 30k miles.
22
3.40%
No problems with the clutch.
412
63.68%
Voters: 647. You may not vote on this poll
I don't believe it! Is everyone's clutch dying at under 10k miles?
#347
Revhappy the cars that you talked about are not awd. If you want to drag race don't do it on public streets. If you launch your car hard a destroy your clutch don't expect it to be covered under warranty. Any manufacture if they inspect your clutch and notice hot spots will not warranty your clutch.
#350
I Have just under 5k on my clutch and have had no problems. Iv done a couple of launches kicked it sideway once or twice and ripped a axis spin once. Other then that i dont drive to agressivley i just cruise around until something worthy rolls up next to me. My buddy with an MR has launched hes car a bunch and done a couple axis spins and has over 10k on is clutch.
#353
I need to know for certain if my clutch is slipping. Its been getting a little worse and I only have had the car for 2 days. when you get on the gas and shift up the car revs freely while I shift 500 sometimes 800 rpms. I believe this is the stock clutch going out but I need to be sure. Sorry I'm a newb.
Edit: This is only when I go say 4k rpms just driving the car normally keeping it under or around 3k it doesnt do it.
#355
Here's the thread btw
https://www.evolutionm.net/forums/sh...hrottle+sticky
https://www.evolutionm.net/forums/sh...light=RPM+rise
#356
My friend has an sti and has made numerous track visits, one of which he made 20+ passes. His car last night still pulled a 1.74 60ft. All that "abuse", and it is still holding strong. Must be nice.
#357
Originally Posted by NYREDEVO
Sounds like ur clutch had the crap kicked outta it during some hard test drives! Go back to Mitsu right now!
#358
Originally Posted by webguy330i
Sounds like the previously discussed throttle issue. I ended up figuring out how to drive around it, but for the longest time it bugged the **** out of me. It revs up a bit for like 1.5 seconds right? Then all is well? When you re-engage the clutch, it feels solid and grabby still correct?
#359
When I got my evo it had 200 HARD miles on it. I drag-stripped it 9 times and auto-crossed 2 times. When I traded it in it had 24,xxx on the stock clutch.
The car had over 300+ whp by 1200 miles. I beat the **** out of it and never had a clutch issue.
Conclusion: No problems here. I miss the evo badly and would recommend it to anyone. Now if only it wasn't a mitsubishi
