Head Gasket Failure !
Old Aug 27, 2003, 09:00 AM
  #31
In Timeout
5StarSuzuki's Avatar
Who should be worried about this problem. What if we simply have an exhaust which increases boost pressure minimally? Kinda scary... Ill pay the 500 for precaution probably...
Old Aug 27, 2003, 09:08 AM
  #32
Alfriedesq's Avatar
To me - I rather do it and know its right than risk taking out my whole engine and had over some stupid thing I knew about
Old Aug 27, 2003, 09:24 AM
  #33
HobieKopek's Avatar
Is it possible extreme heat (enough to melt the gasket) could occur without detonation due to the use of race fuel?
Old Aug 27, 2003, 09:48 AM
  #34
AvatarOfWar's Avatar
Evo-Bill's gasket went on 93 octane. I don't think there's any getting around the issue through not using NOS or race-gas, etc.
I'm buying the bolts as soon as Pruven gets them in, who cares what the cost to get them on is? I can afford it over the cost of a new engine.... (although if the motor went, the wife would HAVE to let me get it rebuilt ).
Old Aug 27, 2003, 11:39 AM
  #35
Alfriedesq's Avatar
Its not that kind of issue - all the happens is that the end head bolt just starts to strech a little at a time till the corner of the gasket blows out and thats the end - - its a gradual process and is accelerated with higher boost - higher HP applications - race gas has nothing to do with it
Old Aug 27, 2003, 12:05 PM
  #36
EVOMIZ's Avatar
head bolts
why not 1g bolts instead of 2g bolts?
everyone with 2g cars run 1g bolts
Old Aug 27, 2003, 12:18 PM
  #37
HobieKopek's Avatar
I didn't mean it was the race gas' fault. I mean that may have been the reason you wouldn't have detonation with the higher temps. Wouldn't the excessive heat/pressure that race fuel can handle before detonating make it easier to run leaner (and therefore at higher combustion temps) without noticable knock?
That was my reason for questioning. I guess it wasn't clear. I ask out of sheer curiousity.
Old Aug 27, 2003, 04:09 PM
  #38
Alfriedesq's Avatar
I think its a matter of how much HP you run - - having race gas causes you to be able to run a bit better timing and yoy get more HP - - if you added a boost controller or some other performance gaining mod then the effect would be the same
My theory is that when you go over about 300 whp - thats when they start to strech - - when you get to 400 whp they strech faster
The black pruven evo has 345 whp and they were on the way out
Old Aug 27, 2003, 05:10 PM
  #39
BadBoyBeltran's Avatar
What if you did not lean out the AF ratio with a S-AFC or other AF controller, you think this still woulda happened with 20 psi to redline?
I am sure a lot of you lean your AF ratios from the factory 8.8:1 (or somthing like that) to like around the 11s.
Old Aug 27, 2003, 05:20 PM
  #40
Also, woulnt an upgraded fuel pump fix the #4 cylinder "lean" gas problem?
Old Aug 27, 2003, 05:37 PM
  #41
There is no confirmed lean condition in the #4 cylinder - it was just speculation in an above post.
I think Al hit it - the bolts are just crap and they stretch overtime. The more HP you're generating, the faster the degradation process.
pips
11
Apr 9, 2014 06:09 PM
Roen
Jan 15, 2013 08:44 AM
mitsugsx13
Mar 17, 2012 01:43 PM
Lumpy
Lancer How Tos / Installations
Dec 18, 2007 01:51 PM
megaxxman27
Lancer Troubleshooting
Jan 31, 2004 08:47 PM
Quick Reply: Head Gasket Failure !
