A crazy question?
evo wheel might be too wide for WRXs, I believe the WRX has 16x7 wheels stock, uping to 17x8 might result in rubbing(with stock evo tires). But if it doesn't rub and the WRX's bolt pattern is 5x114.3 then I dont see why not.
Nope, WRX's...and just about any other Subaru...have a 5x100 bolt pattern. Plus, they need a +53mm offset or so. Otherwise it will jackup the handling. Not sure what the offset is on ours though...
Even if the bolt pattern and offset was right (which they aren't)the WRX wagons in particular have clearance issues requiring them to typically run smaller 215 45/17 tires and a smaller width 7" wheel. The Evo wheels would just be too wide.
Too bad though as they would look great on a white, or black wrx wagon!
N10S
N10S
Imtheking24
Sep 9, 2015 11:42 AM
HumanCapital
17
Oct 25, 2007 04:02 PM
djmikeymike
Nov 23, 2004 05:18 PM
XRS-Lift
Oct 8, 2003 11:30 PM
