ACD and AYC
Originally posted by 5StarSuzuki
Just wait for some aftermarket differentials come out... you don't want the oem stuff if you plan on racing. If the AYC differential breaks, have fun!
Thats right, the ayc pump and pressure switch ain't cheap, not to mention the diff itself! Just to shed some light on this issue. In Jamaica we have quite a few AYC cars that enter drag racing in the 12 and 13 class. None in the 11s class yet....
Interestingly enough, we have had only 1 AYC failure which was traced to a defective ayc ecu. This is a different situation to that of the blokes in the UK.... they have quite a few failures. Granted, they have more evos than we do. It may have something to do with the temperature difference or the fact that our mechanics only use synthetic oils in the hydraulic / AYC clutch system vs. the mineral oils that mitsu recommends.
Americans are blessed with a great Evo 8 .... GSR interior with the Pre - E7 RS driveline... IDEAL for racing. In fact i was told that a local drag racer is importing the US model precisely for this reason!
Re: Not in the USA
Originally posted by ESCALVANTE
Nope. In their place is smog equipment. Another reason they did not bring it over to the US is to keep the cost down.
Re: Re: Not in the USA
Originally posted by tryandcatchme
I disagree, It was more of a reliablity issue.
That is only partly true. Remember that the EVo 4-6 AYC pump unit is no longer made. The Evo 7 & 8 use a different pump which also supplies pressure for the ACD accumulator. For to introduce AYC to the states they would have had to include ACD too... the cost of the car would have gone up. (the ayc/acd pump is ~ 1130£!!)
But I do agree with you that the Active driveline is high maintenance and not as proven/reliable as the driveline you guys have in the states (well with exception of the clutch and 5th gear problems// whats going on with that anyway??)
Re: Re: Re: Not in the USA
The 1130£ cost for a new AYC/ACD pump is if you buy the unit seperately. Any genuine Mits replacement pars that you need for the evolution especially for an electronic differential is going to be expensive. Even if they figured out a way to get AYC/ACD to hold up forever, and they ended up putting it into the next version, I dont think it would put the car up that much in cost.
I really dont care for AYC anyways, id rather control the movement of the car myself.
