So how do you run the wiring for a boost guage?
I certainly wouldn't want some monkeys ripping apart my dash and firewall to wire up a boost gauge or the triple-gauge pod set that is an accessory for the Evo.
What's the story?
What's the story?
Do you have a mechanical or electronic boost gauge?
It's different. You need to run a vacuum hose over the firewall for mechanical boost gauge. You will need to run a wire to the sensor (included) over the firewall for electronic boost gauge. As for the gauge itself, you will need to wire it up with 12v + ground.
Here is a great article by Dan Hetorilla:
http://www.collectracecars.com/evo/mechgaugeinstall.htm
