HKS Hiper EVo8 Cat Back
I'm the HKS importer for Panama Central America, the item is on B/O till next month, there are several people around here that has the system running. I just wanted to know if any of the vendors around here might have 1 in stock.
Originally posted by gldenchld
Not backordered, just not released yet. Should be in a couple of weeks. No one has it , dont think about buying the evo7 cause it wont fit.
The 7 is built for a car with a shorter bumper. You can use it. You can modify it, but it was meant for a shorter length.
BTW, the HKS Intercooler should be available soon too.
Coprrect - you CAN use the HKS cat back - and weld in an 02 sensor bung, and lengthen it by about an inch.
If you use it without lengthening it, you most likely will be painting your bumper within the nexty 6 months, as the paint will begin to opeel without a doubt (the stock Mitsu paint stinks).
HKS's cat back should be out in the next month or so, so hang tight!
