E brake adj. for EVO VIII???
1 Post
hey guys I have always noticed a little slack on my e-brake. Where do you adjust the slack???? I pulled off the arm rest thinking it was there but no dice!
Any suggestions people????
![Confused](https://www.evolutionm.net/forums/images/smilies/confused.gif)
There is a 10 mm nut that you turn. Do this a little at a time though. Tighten pull the brake, tighten pull it again.
It should click no more than 5 to 6 times when done. Any less and your brake pads could drag, less and you might not pull it enough and they might not engage fully.
Raist
Raist
