Odometer swap
it is definitely stored in the cluster not the ecu or anywhere else
only way to find out would be dealer notes for service or car fax for things like inspection
but that is not even for sure because you can swap out the odometer on the car to another one, let the miles build up, then inspection time or dealer time swap it to the original and the miles are still low
how do u figure it has more miles on it anyways?
japspec (Dec 3, 2018)
i actually just did this on a saturn(lol). some tweeker was installing a redline interior into an ion 1 sedan. cluster and all. the cluster had it's mileage in it and the body control module actually stores the real mileage. the cluster worked but mileage was not clocking. i called the tech assist center and asked if i could retrieve the actual mileage for him. (although i knew i couldn't, just trying to please the customer.) TAC told me if the cluster was new, the bcm would populate the cluster with it's number. if the bcm were new, it would populate the numbers from the cluster. change both without knowing the true mileage and you would have to get a sticker from the dmv. (unknown mileage.) i would say if the mileage is clocking, it may have the correct mileage. but like everyone said, take it to the dealer to be sure. good luck.
no laughing matter, check with your local legislation. here is floridas law stating its a felony. It is a Felony for anyone to knowingly tamper with, adjust, alter, set back, disconnect, or fail to connect an odometer of a motor vehicle, so as to reflect a lower mileage than the motorvehicle has actually been driven
http://www.flhsmv.gov/
So in conclusion, unless the person that sold this Evo was stupid and would risk getting a felony for a couple grand. This Evo was simply treated like s***t for the low number of miles that it was driven for. It happens, I've seen cars with low miles look like crap, and I've seen cars with a high number of miles look very clean. It simply depends on how they were treated.
hey guys sorry i have not gotten back about your questions i have not been on too much lately. So, my friend that bought the car decided to talk to the previous owner about it after reading up about the location of the mileage. The previous owner couldnt answer any of his questions and said that if he didnt have a phone call by the end of the day to come and pick up his money that he would be calling the athorities about a fraudlent report of mileage.
taaadaaaa ! the end of the day his phone rang and he promptly went over and picked up his $$$$ and dropped the car off to the ripoff artist.
In the end it all worked out, he got his $$$ back and now he said he wont be jumping into another evo without fully checking it out.
thats pretty nuts... I know someone who had their Acura TL Type-S modified so that you flipped a switch and it stopped counting miles but also the speedo didnt work. Kind of sucked because the more miles the thing got put on it the worse the car would run due to missing repair intervals. the car was financed and eventually it got picked up because they defaulted and luckly nothing has come back to haunt them for the bogus mileage
