HID headlights question
i got a regular evo 9, i guess the gsr without the ssl package, not sure about this, but i wanna get the hid headlights and foglights, can the housings and lights just be swapped out and will it all plug and play, not sure if the wiring is all there for the fog lights and hids???? anyone done this or know???
any help greatly appreciated
![Confused](https://www.evolutionm.net/forums/images/smilies/confused.gif)
which means you would still have to swap out the projectors for the correct cutoff.
As for adding in hids, you won't have the stock leveling motors or switch, that is if you want/need em. but they are kinda cool.
![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
but then if you get the real jdm lights you will have the jdm cutoff.
As for adding in hids, you won't have the stock leveling motors or switch, that is if you want/need em. but they are kinda cool.![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
Yes, the JDM headlights do not plug and play. For it to be factory you need the USDM hid headlights, headlight harness, fuse box, fog and leveler switches, wiring diagram and time. You could just buy a HID kit for your stock projectors slap them on in 30 min. and call it a day but no fogs. For JDM's, wire up your own plug and play harness for the hid and fogs (the RHD beam pattern is not a big issue to most). The leveler motors can just be left unpluged. Easy stuff. Oh, and SEARCH. There are quite a few threads that have more details on this topic. Good luck.
Found this old for sale thread. Thought it may help you out a bit. Seems to have some explanation
https://www.evolutionm.net/forums/sh...hid+headlights
