hmmm what to do???
hmmm what to do???
ok winter is coming so i just got a set of blizzak ws 60's and my next step with performance is cams and headstuds with a retune cost = 1100 approx. or should i get the COBB ACCESSPORT AP-MIT-001. cost approx = 700, or should i just wait to spend my money till next spring...???? cuz i cant be racing with these tires on....
mods are good i went to ams and told em the list and they suggested the cams and headstuds, but im thinkin wait till next spring to be able to f*ck around with that kind of power, and just go with some engine managment
your car with cams will never run as good as a stock car. no matter what anyone says. if you don't care get the cams. next you will want a turbo kit and then next you will run race gas all the time like me. forget the cobb computer. just go with the stock ecu then go with the ems.
Car runs perfect with cams as long as you get it tuned. Hence the reason so many people do it. Also I would stick with stock ecu I have a htagt35r setup and am using the stock ecu.
1 Post
Wow what are you people talking about. Car will run perfect with cams as long as it's tuned right. That's a good power mod as well as wfp, and all your air mods.
Ems is good but kinda too early for all that imo
DO NOT get anything cobb for ur evo. cobb is for subaru's. expecially not the access port. The evo's stock ecu is good for well up into the 500hp range. If any computer change is desired id suggest going aem ems but thats not till u have built motor and big turbo.
cams r good. turbo upgrade is good. fmic, fuel pump, injectors, boost controler, boost gauge, exhaust, intake, suspension (lower). Those should be what you should consider for now
Yea Access Port for the EVO VIII and IX is a paper weight. With stock ECU Mods and Software out now.
Search the ECUFlash forum all info you need to get started is in there.
PM my man Tamer. 4WS Tuning he'll get you everything you need, explain it all, and your car to will be "Faster than a Cheetah on Cocaine"
Peace
Peace
Conrad
Mar 8, 2010 11:26 AM
