Water Leak in back floorboard?
We had a hard rain hear in NC yesterday evening. I went out today and happened to notice that the backseat floorboard on the passenger side was slightly wet. It was about a 12" x 8 " area that was wet. There was also condensation on the back of the floor mat. Has anyone had this problem before?
Brian
Brian
There's a recall on the ECU wire harness area at the firewall. Search the forum. You'll find it. Dealers will fix it. I got the problem repaired before Mitsubishi sent me the mail. Don't worry, nothing major.
I thought there was a recall about the ECU harness. But this leak is at the rear floorboard in just that one isolated spot. I checked the rest of the car and it is all dry. It is only in that one spot. That is what concerns me. This leak is happening nowhere near the firewall.
Brian
Brian
I called my Mitsubishi dealer and told him of the problem. They asked for my last 8 of my VIN. I gave it to them and they called me back in about 20 minutes. It seems that this recall is not on my car. I have a water leakage problem, but I am not eligible for the recall. He said the recall was on the ECU harness at the body junction and not the rear O2 sensor harness that was leaking. He said to bring it by next week and they would try to find the leak.
Brian
Brian
That same thing happened to me. I told my dealer about the recall after reading it here so they ran mt VIN and told me my car wasn't part of the recall. BUT I can hear water dripping by the passenger door in heavy rain.
Crock!
Brian
the firewall is not the only place where the recall relates to. It relates to the seam welds under the car right under the ground effects. There are leaks in the welds and it allows water to get up in there.
Yea, What Favre95 said. I watched them do my car. They ran a big bead of sealent from the front of the car to the rear on both sides. Just inside of the rocker panels. Theres seams inside there and you could actually see where the factory missed some spots. The robot must have been on the fritx for a couple days or something. Definitly get it sealed up or your gonna have corrosion problems. Take it to a different dealer if you have to. Yours obviousley has their heads in their asses.
Not every EVO is involved in the recall. I think it ends with vehicles built from April 11 forward. I have double check my VIN with Mitsubishi twice and with 2 different dealers.
But it doesn't make a difference. If you've got a leak they need to fix it under warranty even if it is not exactly the same root cause as those involved in the recall.
