in the morning
Turn the car on and drive gently until its up the full operating temp. Sitting and waiting is just wasting gas and time; you're doing your car no favors. Gentle driving is the best way to warm up an engine since it helps get heat into everything like the entire drivetrain, not just the engine block.
+1 on the OP saying it depends if your late or not
A lot of people tell me warming up ur car is a waste of time and I do agree if you let your car warm up completely then drive away. Like others have said, once my temp needle starts moving, then I drive away and lay off the boost till its fully warmed up. I hate just driving right away because my car acts like an old b****. I hear all kinds of sounds and gota love the tranny when its cold.
![lol](https://www.evolutionm.net/forums/images/smilies/lol.gif)
I let my car sit and warm up until the temp needle moves above the bottom line.. Then I drive in vacuum until my oil temp needle moves.
Question for everyone who drives out of boost: How far do you guys drive in vacuum? Like far into vacuum (light throttle/engine load) or near boost (0 PSI/I believe this is called perfect vacuum)?
I have a oil pressure gauge and drive according to that because when it's normal that means my car is good to go. It's at 80 when i first crank her up and drops down to 20-30 (normal operating) which is when i get going. the pedal is very sticky before that and if i leave while its still cold my motor surges all sorts of funny ways.
warming up the car is more fuel efficient that running on cold oils in the motor. for some reason your car uses more gas when the car is cold. i did a paper/speech on fuel efficency and i have read, and it has been proven thru testing, that a cold car uses more gas.
Driving the car right after start-up is not going to hurt it.
I let mine run for a minute or two just to make sure oil is getting where it needs to then start driving. I wouldn't drive it hard (boost it) until it's good and warm. Think about it...you don't want to jump out of bed when its 30 degrees and start running as fast as you can or maybe your a freak and you do.
As SME stated, if the ECU detects a cold engine, it will dump fuel until the operating temp raises. Driving your car (under 3K RPM) is the fastest way to raise this temp.
From the California Energy Gestapo:
Here are some other Myths associated with idling.
Myth #1: The engine should be warmed up before driving. Reality: Idling is not an effective way to warm up your vehicle, even in cold weather. The best way to do this is to drive the vehicle. With today's modern engines, you need no more than 30 seconds of idling on winter days before driving away.
Myth #2: Idling is good for your engine. Reality: Excessive idling can actually damage your engine components, including cylinders, spark plugs, and exhaust systems. Fuel is only partially combusted when idling because an engine does not operate at its peak temperature. This leads to the build up of fuel residues on cylinder walls that can damage engine components and increase fuel consumption.
Myth #3: Shutting off and restarting your vehicle is hard on the engine and uses more gas than if you leave it running. Reality: Frequent restarting has little impact on engine components like the battery and the starter motor. Component wear caused by restarting the engine is estimated to add $10 per year to the cost of driving, money that will likely be recovered several times over in fuel savings from reduced idling. The bottom line is that more than ten seconds of idling uses more fuel than restarting the engine.
