SES light after filling up at Mobil?
Ok this happend to me first 3 weeks ago... I filled up on BP 93 octane and as soon as I pulled out of the station bam the ses light goes on... it then turned off by itself after the tank was 3/8 empty. Its been off for 3 full tanks.
This morning I Fill up on MObil 93 octane in Highland Park Il. And same thing... I pull out and the SES light coems on again?
Is this due to winter blend?
Did you fill your tank up to the top? Most manufacturers will not run the evap system check unless the fuel level is 3/4 to 1/4 tank. If you had a full tank at the time the light came on it is doubtful that it is an evap system code. Check codes and post them. Of course it could have just set the light after fill up by coincidence.
brenner
Aug 24, 2009 07:20 PM
