Running Sparco Harness Bar - How to keep rear passeners safe?
haha, damn I really don't wanna carry extra helmets!!! ...though I do have enough trunk space to do it...
Uh...this stinks. I really want to use the harness bar for a camera/video mount as well as adding some structural benefits. Why do they even sell the padding material then?
P.S. screw the passengers. pull out the backseats.
the harness bar alone is a DEATH TRAP in your car (lord forbids) your car turns over or a serious accident. its a decapitation waiting to happen. if you get the harness bar you'll also need the roll bar as well.
They sell the racecar padding because A. it looks good, B. you won't bump your head when getting in and out without a helmet. C. it won't scratch the $2000 paintjob on your helmet and D. it offers some minor protection on in an impact where the driver is wearing the helmet.
Short answer is, keep passengers out of the back while the bar is in there.
Dave
1. remove rear seats. (no pasangers to hurt)
2. if rear seats will stay. buy some 4 point racing harness also for the back seats, so they won't go to the front in case of inpact.
3. if there is no money for such project, forget about everything and keep your stock seatbels
There isn't any way to make this setup safe, padding won't help at all. As others have stated remove the rear seats completely if you have a cage and possibly even the harness bar. This will eliminate people saying "hey, it's just a short trip let me pile in".
When I had my 8, I had everything from the driver's seat back removed and I installed an Autopower 4 point cage. Honestly, I'd be scared to run 4 point harnesses without at least a hoop or half cage in the car...so harness bars for me aren't even an option.
This logic is very very wrong... I'm not sure of the exact numbers, but if I remember from Physics classes if your car is travelling at 60mph and you hit another car travelling at 60mph, the forces involved in the collision would roughly triple your body weight (I know the numbers are probably wrong but you get my drift). Holding onto the bar tightly will probably just injure them more and most likely break their arms.
Collisions at 20mph can be just as dangerous...so if you're not "planning" to do more than 80mph it doesn't matter.
I dont see the harm in it as long as there holding on to the bar really tight.
Hey its better than flying through the middle and on through the front windshield right?
But i wouldnt take people in the backseat if your going over 80+ mph
if you are then surround it with a polyethylene foam cylinder *under $20*
Theres a reason this isn't for street use. I believe you can mount your harness use the latches for a baby seat... I believe cause i've seen harnesses w/o a harness bar.
