brake lights
brake lights
need some help,
when i am driving at night and my head lights r on, my brake lights light up as if i was braking at all times. when i hit my brakes there is no difference. is this a short somewhere? need help
thanks
Dan
thanks
Dan
disconnect the break light switch. If your 3rd light still comes on then you have a short.
Most likely the short will be local in/or around close to the switch.
Any other short i have noticed will burn up the fuse and throw out the license plate lights. or the parking lamps.
Check the new bulb you installed. It's either the wrong type, or installed backwards (too lazy to check which bulb it takes, but dual filament bulbs can only be installed in one position, you can install them 180 degrees out, but you have to force it in place). What's happening is the marker light circuit is now powering your brake light filament in the incorrect bulb.
I know this is a little off topic, but I was searching a could not find anything but was wondering what it meant if my parking break light wont go off when even when i put the break down anyone know why that is?
99% chance your brake fluid is low. 99% chance that is because your brake pads are getting low. I'm pretty sure this is in your owner's manual.
