Beatrush Undertray Install
Hey whats up man. So thats what the cam money went towards .Looks good, and i like the idea with the fasteners. Ive been thinking about one of those beatrush trays because the stock one is junk.
Oh yeah by the way i got the cams a few days ago. Thanks, everything was in perfect condition. I havent installed them yet. Im still waiting for my fuel pump,timing belt kit, and headstuds to come in.
It was good doing biz with you scheides. +32132754275385348765
Noticed you wrote that you made minor modifications to make those fasteners fit. Those fasteners look like real nice pieces, what modifications did you make and to what pieces (lip, underpanel, etc)?
And those dzus fasteners, how do you mount the square looking piece?
It's all aluminum so it this is all *super* easy work. I was telling a friend just now that I think that I spent less time installing it and fitting the dzus fasteners than I would have just installing the pile of regular allen-bolt hardware that came with it.
4-8" of snow coming here tonight, so it'll get put to immediate use....
Gave this thing a good test last night, we received a bunch of snow here in MN. Large snow/ice chunks in the road, some small drifts, and unplowed stuff, 4" or so. Undertray works great
I was thinking the same thing - I may buy a set of 4 to try them and see how they could work with the stock under tray. These fasteners could make life much simpler...
thanks for posting the link for the fasteners
Yup yup, they would probably work with the stock undertray, but if you're taking it all apart anyways, why not just go for the Beatrush? MAP has a bunch in stock right now, I saw them when I was there picking mine up. It's xmas, spoil yourself, and protect your car....
Excellent job on the install!! Just a quick clarification, you listed you only need to do 4 fasteners for an oil change. I am assuming you are dropping the rear panel and I always have to drop 5 screws 3 then 2. Am I correct?
Also Which fasteners on that site did you actually use???
This is the actual auction that I used:
http://cgi.ebay.com/ebaymotors/ws/eB...m=200273287716
You can get them from kurveygirl.com, too. The important thing is that they are 7mm wide (not super important, you can always drill holes bigger!), 12mm fastener length, and 15mm overall length. They are the 'snug fit' fasteners for ducatis.
Aero seems better designed, overall it is flatter, stronger, and it all comes off really easily once you put these fasteners on! Also it goes back farther, covering the oil filter (good for protection). If you wanna know why I wanted one of these, look here:
http://www.scheides.com/gallery/evotimingpulley
but this pic says 1000 words:
I don't think this is actually true. It doesn't mount rigidly enough to any body structure pieces that would actually accomplish this. It might help a *little* but not much. You're probably feeling the better aero
Also, just so I don't get spit on by someone, I am not the first to do this.
https://www.evolutionm.net/forums/sh...d.php?t=308962
dont want to replace mine yet since it is still in one piece.
