floor jack
Old Dec 14, 2008, 11:05 PM
ch53avitech's Avatar
floor jack
For those of you who use floor jacks, what do you do to prevent your lifting points from looking like this
[img]
[/img]
Old Dec 14, 2008, 11:37 PM
boostless's Avatar
the lift points are closer to the front wheels, where the sheet metal is folded in a multi-layered fashion. Otherwise, go from the front center jack point.
Old Dec 14, 2008, 11:43 PM
What jack do you use that reaches all the way under the car to the center jack point?
Old Dec 15, 2008, 12:00 AM
Broxma's Avatar
To prevent the lift points from ending up that way, don't use those lift points. Pretty much any low profile floor jack can reach the pseudo frame rails just inside the factory lift points. Those frame rail things take a bit of a beating but with the right pad on the jack, it doesn't hurt them at all.
I got a steel/aluminum low profile floor jack from HF that reaches the front lift point with no problem. It has an 18" extended height and cost me 115 bucks I think. It's high enough that you can lift the car, put it on stands, and slide the tranny out the side which, in place of a lift, is about all you would need a jack for.
/brox
Old Dec 15, 2008, 03:52 AM
Chemwarrior's Avatar
I use a block of 2x4 wood has a cushion. That prevents alot of those dented areas.
Old Dec 15, 2008, 04:07 AM
evoWWrs's Avatar
omg... i have never seen that before!!! i use a craftsman 3ton jack but only jack right after the wheels where it makes a T
Old Dec 15, 2008, 01:23 PM
enVmyIX's Avatar
2x4 for me too, if i want to get to the front center jack point i first jack up by the tire, then hold it up with a stand then put the jack in position for the front center point
Old Dec 15, 2008, 01:28 PM
eVosmAs2006ix's Avatar
You can use a hockey puck, 2x4 block of wood, or hard folded cardboard (is what i use and works like a charm, I found out the hard way like you too when I first did one corner.
Old Dec 15, 2008, 01:29 PM
ExplosEvo's Avatar
I dont use anything...but mine doesnt look nearly that bad. Maybe its just your jack. Does it have a small seat that contacts the car?
Old Dec 15, 2008, 01:36 PM
19DB794's Avatar
My floor jack has a cushion on top. Ive only used it 3 or 4 times so far and my jack points look the same way as they were when the car was brand new.
Old Dec 15, 2008, 02:03 PM
Well the jack I used has a solid plastic jack head so there's not much cushion for the car. That's really all I need to prevent the jack points from looking like that, a better cushion.
Old Dec 15, 2008, 08:35 PM
bso
bso's Avatar
How about this: http://www.eastwoodco.com/jump.jsp?i...emType=PRODUCT
Old Dec 15, 2008, 09:16 PM
smacksevo's Avatar
And Bingo was it name-o!
Old Dec 16, 2008, 03:41 AM
smp3000's Avatar
I was just watching Tropic Thunder and immediately thought of "Simple Jack" when I saw this thread.
But yeah if yo have to use a 2x4 as a cushion, BUT be careful. I did that once and the 2X4 brok and the jack slipped and the car fell a good 4 inches. The rear window shattered and the jack nearly went through the bottom. Huge bump in the front seat foot area. Luckily this was not in my evo.
Old Dec 16, 2008, 06:42 AM
boosted2x2's Avatar
i dont jack car up on sides. i use diff or front lower brace and jack stands under control arms.
Quick Reply: floor jack
