engine swap
wait.. you want a new engine because yours is high mileage? are there any problems with your motor or you just want less miles on it? seems silly.... especially when you could just refresh your current motor.
besides for an 06 swap, you would nee a lot more than just the motor. need an 06 ecu, and then there might be an issue with yours not having acd. not sure if the ecu would be compatible. im sure someone more knowledgeable than me will chime in on that one.
i just want less miles on it...if there is a way to reduce miles without an engine swap then that would be the best way and my bad i meant 03 engine...i typed 06 by accident
no.
but what you could do is build the motor, it would essentially be like brand new. your mileage will not go away, as its illegal to tamper with your odometer.
i cant believe im giving this so much thought
there are any number of companies and ways to freshen up your motor from cheap drop in pistons/rods to a full out build. you have a lot to learn and the search button is your friend. this thread is giving me a headache. i really hope youre not this dense
