Evo 8 Guage Cluster Question
Does anyone know where to get all the 12 or so little bulbs behind the guage cluster to light it up? Or the kinda of bulb? Ive been having a hard time finding out, any information would be great!
Thanks so much
Kevin
Thanks so much
Kevin
Go to your dealer and have the parts guy get the schematic for the gauge cluster. There are four bulbs behind the main gauges, and three of them blew in my 03, making for a very dim instrument panel. It's qute easy to pull the whole thing out and replace the bulbs. They cost about $4 each, last time I looked.
I tried to do a search in the DIY section for the posts that detailed this, but the search engine doesn't seem to be working at the moment. To remove the gauges, unscrew the three screws on the underside of the coaming and the clear plastic face will come out. Then you simply pull the gauge panel itself towards you, unhook the wiring harness connector, and access the bulbs from behind. They come out with a slight twist.
mazdryk
Apr 30, 2020 08:31 PM
