Aem tru boost question
Did you mean, to use the gauge as just a boost guage? Because if you unhook the solenoid obviously you can't control boost with it.
The stock boost(wastegate) solenoid will not control boost well after a certain boost level. You need some type of aftermarket solenoid to control boost using an ECU.
If you are going to unhook the AEM wastegate solenoid, what are you going to use to control the wastegate?
RansomRacing
12
Aug 25, 2007 09:37 PM
