Anything I should kno before I buy a Evo ?
Hey guys,
I finally decided to get away from hondas and buy myself a Evo VIII. Brfore I do however, does anyone have any positive or negative feedback about this car.
thanx guys
thanx guys
Just don't smoke the clutch. They are a little on the soft side and they will heat up easy and you will smell it so just be carefull. That is probably the best advise I can give you other than break it in correctly. Have fun!
![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
If you equip yourself with a stainless clutch line from Alamo or LancerShop and install it after break-in, you should be good to go as far as clutch longevity goes. Just don't drop it at 7k from a dead stop and you should be fine.
Oh, don't forget to remove the restrictor valve & spring from the solenoid, too. You won't be disappointed.
