Ebay Harness Bar?
From a design standpoind the Ebay piece looks to be pretty sound. I like the fact that plugs are welded into each end of the tube. Assuming, they extend into the tube a ways, this will create a stronger connection point to the tube than just welding it to the seat belt flange. The flange that connects to the upper seatbelt bolt also looks to be a pretty good design. The bar mount is welded perpendicular to the flange. This creates a gusset for the flange making it stronger. You do have fasteners in double shear but if you select the proper size/grade that won't be a problem. The lower bars aren't so much of an issue but look to be the same as most designs.
The only thing i don't know is the materials and welding process. That will probably keep me from using it. As far as the design goes it looks just as sound as the big name units. Infact, i would prefer this mounting design over the sparco unit.
It looks good some ebay stuff is good buy it test it out let us know
we should have an ebay thred i had exhaust on my 9 for 3 years problem free & it was 230 shipped for turbo back made over 500 hp on it too
All this talk has lit a fire. I am going to design and build my own harness bar. I may build a few more and try to sell them if it all works out. Time to get my mechanics stuff out and go to work. I will be using SolidWorks to model/ make the prints. I will probably also use it to do some light FEA as well.
different grades of metal make the difference between good and bad quality. For instance, if you could smack it against the ground or bend it with your foot when you kick down on it----it's probably a very low grade folded metal----whereas the higher grade metals are harder, folded over better and tempered better, to be less brital---thus they are more expensive---
kinda like if you're the type of personwho buys knives----the expensive knives look just like the cheap knives---difference is high grade metals are usually used in the expensive ones---hence the price---
you get what you pay for----and when safety is on the line----don't buy a cheap one, unless you are doing it for aesthetics only, and don't ever intend to actually rely on it....even then it's kind of a waste of cash.
A lot of brand name manufactures have their products manufacture in South East Asia to save money and they turn around sell them at mutilple times of the cost. But a lot of ebay parts are made here in America by quality people that willing to sell car parts at a reasonable price. For example, SS autochrome O2 housing, and I am sure there are others great products too.
Yes there are more properties that determine the quality of metal. I only gave one (the one most likely relevant to ebay-quality metals)
Had you wanted a more in depth explanation as to the determinants of "quality" I'm sure I could write you a more in depth, detailed, justification---not like you need it, but just sayin----I figured the fore mention of how it is tempered (which is one of the highest determinants of a metals end-state fabrication quality) would be enough to satisfy the original posters question, which was asking the quality of an ebay product---i gave a brief description as to a few reasons and ways it is NOT a quality product.
Take a high-grade piece of metal, temper it wrong, and you can smash it with a hammer like glass because it has become far too brittle-----not saying that's the case with ebay products----but i'm sure its not all that far off.
Ebay is just a market place where you can find a lot of products, can't really put a "=" sign between ebay and quality. there are tons of brand names products on there too. How do you know that brand name product is always safe? are they all DOT approved?
An o2 housing doesn't pertain to safety
For the record, a harness bar really isn't a safety part anyway. Its purpose is to stiffen the chassis and provide a place to attach harness'. In the event of a rollover it will probably do more harm than anything to you. There have been issues of them causing spine and neck injuries. So really if you are looking for safety, rollcage.
[WTB] Sparco harness bar
mrbonilla
Nov 16, 2016 03:58 AM
FS[Northeast]: Harness bar
jakub
Mar 1, 2015 12:19 AM
marshall15
Aug 21, 2006 07:19 PM
