Aem gauges
Old Mar 20, 2009, 02:18 PM
  #46
EvolNinja's Avatar
Originally Posted by topturtle
Sorry for the bad pic but you get the idea
Nice setup
Old Mar 20, 2009, 02:30 PM
  #47
topturtle's Avatar
I dont mind the numbers bouncing around. The AEM gauges are a little bit on the expensive side, but after going through two sets of Stri boost and oil pressure gauges I bought these. The Stri worked good though. They just didnt like being pegged out so much.
Old Mar 20, 2009, 03:55 PM
  #48
lhausi's Avatar
very nice setup shown above. i slapped mine into the glovebox with the autometer triple gauge holder, going for the conservative look. i got the aem uego and truboost. i kinda wanna get the aqumist one shown above too, that's a hot gauge.
the aem ones are on the expensive side, but imo well worth it. i wouldn't trade them for anything else
Old Mar 20, 2009, 05:01 PM
  #49
chad99evo's Avatar
Originally Posted by Hikaru
anyone have pics of their AEM gauges installed?
check out the show and shine forums and find the interior or guages thread
Old Mar 20, 2009, 05:34 PM
  #50
yadoh's Avatar
aem wideband is probably the best bang for your buck wideband
Old Mar 20, 2009, 05:42 PM
  #51
joshevo22's Avatar
Originally Posted by randomevo
from my how to, imagine 2 more gauges
How did you get your gauge to read negative?
Old Mar 21, 2009, 02:52 PM
  #52
yoteru's Avatar
I had them on my old s13 and they worked great
Old Mar 22, 2009, 06:10 PM
  #53
Corey's Avatar
I noticed in your sig that you have the AEM boost gauge. From what I've read, only the Tru boost actually reads in vaccum and the reguler boost gauge doesn't.
Old Mar 22, 2009, 06:48 PM
  #54
EVOKRAZY8's Avatar
I got the AEM tru boost with boost gauge and it works fine. Confusing as hell to set it up but it works and now im pushing 24 psi.
Old Mar 23, 2009, 07:52 AM
  #55
midegade's Avatar
Originally Posted by Mr. Evo IX
AEM Uego is directly supported in Evo Scan for logging. ECU Flash is a flashing application for the stock ECU, it doesnt log. You need to connect the serial out from the gauge to a 9 pin serial connector (Radioshack $2.00).
Thanks for the info.
Do you know of the Innovative wide band.
I was planning on using that before I read here about how good the uego is.
Logworks 2.0 is the logging software which use Innovative WBo2 and also has Ecuflash supports so just wanted compare.
Old Mar 23, 2009, 08:43 AM
  #56
[GBU]Moon's Avatar
I have the AEM UEGO wideband, and the only thing i could think of as a negative is the noise it makes. i keep my stereo up, so i rarely ever hear it, but do all of them make a soft grinding noise?
Old Mar 31, 2009, 11:36 AM
  #57
midegade's Avatar
Is this the cable I need.
The DE-9 D-sub 9-pin connector?
Old Apr 1, 2009, 06:45 PM
  #58
NickB13187's Avatar
i have 3 and they all work fine
Old Apr 1, 2009, 06:57 PM
  #59
randomevo's Avatar
it always did, apparently it was an update from the older versions i think?
Thats vacuum at idle.
Old Apr 1, 2009, 07:14 PM
  #60
billsIXmr's Avatar
i have aem a/f had no problems i will be buying more
Kustom09art
Aug 4, 2015 07:38 AM
maxroach
May 24, 2015 12:43 PM
mr2driver
Mar 20, 2013 07:21 PM
Maximum404
Apr 25, 2009 07:03 PM
EVOMIZ
AEM EMS
May 29, 2006 10:21 PM
Quick Reply: Aem gauges
